Ir para o conteúdo principal
iView-776TPCII Rear Panel Replacement
O que você precisa
    1. iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, imagem 1 %32 iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, imagem 2 %32 iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, imagem 3 %32
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      Pergunte ao FixBot
      Comentar
    2. iView-776TPCII Rear Panel Replacement: passo 2, imagem 1 %32 iView-776TPCII Rear Panel Replacement: passo 2, imagem 2 %32
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 2-2, Baechle Fall 2015 Membro de IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 792
