Ir para o conteúdo principal
iVIEW-754TPC Camera Assembly Replacement
O que você precisa
    1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, imagem 1 %32 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, imagem 2 %32 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: passo 1, imagem 3 %32
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Pergunte ao FixBot
      Comentar
    1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, imagem 1 %32 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, imagem 2 %32 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      Pergunte ao FixBot
      Comentar
    2. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: passo 3, imagem 1 %32 iVIEW-754TPC Camera Assembly Replacement, Remove Camera: passo 3, imagem 2 %32
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Robert Clark
Membro desde: 01/21/15
1.065 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 5-4, Brown Winter 2015 Membro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 512
