Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will teach the process of unseating the motherboard from the iRulu AX760, whether to replace the motherboard or simply to get to the screen. These steps are reversible to re-seat the motherboard.
  1. Use a plastic opening tool or metal spudger to free the rear cover. Insert your spudger into the side of your tablet. Crack open each edge and remove the cover.
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. Open your tablet.
    • Open your tablet.
  3. Take your plastic flat head tool and insert it under the battery.
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard. Keep the wires of the battery taught.
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Como soldar e dessoldar contatos
  6. Remove your old battery and replace it with the new battery.
    • Remove your old battery and replace it with the new battery.
  7. There are two thin adhesive strips under the battery that run vertically along the left and right side. Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  8. WARNING: SOLDERING IRONS BECOME EXTREMELY HOT.  DO NOT TOUCH For information on soldering and desoldering, check this link. You must desolder several sets of contacts before attempting to remove the motherboard.
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  9. Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  10. Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard. You will not need a metal spudger in order to re-place the motherboard
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
Conclusão
Adam Schubach
Membro desde: 20-03-2018
123 Reputação
Autoria de 1 guia
equipe
IUPUI, Team S6-G4, Baechle Spring 2018 Membro de IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 118
