Introdução
This guide will teach you how to disconnect the camera of your iRulu AX760 and remove it from the device. You will learn how to disconnect digitizer ribbons in this replacement process.
Peças
Não são necessárias peças.
  1. Use a plastic opening tool or metal spudger to free the rear cover. Insert your spudger into the side of your tablet. Crack open each edge and remove the cover.
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. Open your tablet.
    • Open your tablet.
  3. Take your plastic flat head tool and insert it under the battery.
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard. Keep the wires of the battery taught.
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Como soldar e dessoldar contatos
  6. Remove your old battery and replace it with the new battery.
    • Remove your old battery and replace it with the new battery.
  7. Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets. Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  8. Pull the digitizer ribbon cables straight out of their sockets.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. Pull the camera out of the device.
    • Pull the camera out of the device.
Conclusão
Jamison Kritz
218 reputação
2 Guides authored
Equipe
IUPUI, Team S6-G4, Baechle Spring 2018 Membro de IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Membros
8 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 39
