Ir para o conteúdo principal
iRobot Roomba i7 Filter Replacement
O que você precisa
    1. iRobot Roomba i7 Filter Replacement, Filter: passo 1, imagem 1 %32
      • Flip the iRobot Roomba i7 so that the underside is facing upwards and the back is facing you.
      • On the left side at the back press the release button for the waste bin.
      Pergunte ao FixBot
      Comentar
    2. iRobot Roomba i7 Filter Replacement: passo 2, imagem 1 %32
      • Once the bin is removed, empty any waste into a trash can.
      • Be careful while emptying. Dust may escape and cause allergies.
      Pergunte ao FixBot
      Comentar
    3. iRobot Roomba i7 Filter Replacement: passo 3, imagem 1 %32
      • Locate the filter on the side of the bin.
      • Placing your fingers on the light grey area, pull the filter directly out of the bin.
      • If replacing the filter, follow these steps in reverse order.
      Pergunte ao FixBot
      Comentar
    4. iRobot Roomba i7 Filter Replacement: passo 4, imagem 1 %32
      • To clean the filter, tap it on the inside of a trash can.
      • Be careful not to shake dust everywhere; it may cause allergies.
      • Do not clean the filter with any type of liquid.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Question, please! I am unable to pull the filter out of the bin. It’s stuck. Any suggestions?
Christopher Liddle - Responder Compartilhar
This little filter barely does it's job. even after installing a brand new one, it'll be huffing and puffing dust everywhere it goes. My old Eufy 35C did a much better job than this much more expensive Roomba.
w.vries - Responder Compartilhar
I replaced the filter but it’s still not working.
Ashley Marie Vazquez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 59
Últimos 30 dias: 204
Ao todo: 14,300
