Ir para o conteúdo principal
iRobot Roomba S9 Plus Corner Brush Replacement
O que você precisa
  1. iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: passo 1, imagem 1 %32 iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: passo 1, imagem 2 %32
    • Place your Roomba upside down with the brush module facing you.
    • Push the grey tab by the top left corner of the brushes to release the retaining arm.
  2. iRobot Roomba S9 Plus Corner Brush Replacement: passo 2, imagem 1 %32
    • Lift the retaining arm away from the brushes.
  3. iRobot Roomba S9 Plus Corner Brush Replacement: passo 3, imagem 1 %32
    • Unscrew the four 11mm Phillips #2 screws holding the vacuum brushes in place.
  4. iRobot Roomba S9 Plus Corner Brush Replacement: passo 4, imagem 1 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 4, imagem 2 %32
    • Remove the brush module by pulling up from the sides.
  5. iRobot Roomba S9 Plus Corner Brush Replacement: passo 5, imagem 1 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 5, imagem 2 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 5, imagem 3 %32
    • Unscrew the 7mm Phillips #2 screw holding the corner brush head in place.
  6. iRobot Roomba S9 Plus Corner Brush Replacement: passo 6, imagem 1 %32
    • Flip over the brush module to access the corner brush motor.
    • Unscrew the 15mm Phillips #0 screws holding the motor in place.
  7. iRobot Roomba S9 Plus Corner Brush Replacement: passo 7, imagem 1 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 7, imagem 2 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 7, imagem 3 %32
    • Carefully take the motor axle from its housing.
  8. iRobot Roomba S9 Plus Corner Brush Replacement: passo 8, imagem 1 %32 iRobot Roomba S9 Plus Corner Brush Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the wire connecting the motor using tweezers to pull out the connector.
Conclusão
Lance Brown
Membro desde: 01/23/20
348 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G3, White Winter 2020 Membro de Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
Membros da 4
Autoria de 9 guias
2 comentários
Wish there was a way to replace that plastic. Stripped on mine.
Steve Yeung - Responder
Hi!
Is it possible to change just the plastic part where the brush screws in?
They did a really dumb thing and made a metal screw go in a plastic thread so of course, the plastic thread finally gave in.
Piotr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Duração total: 2,448
