Introdução
This guide will teach you how to access, remove, and replace the side brush motor of the iRobot Roomba 692. If you are replacing the side brush, ensure that you have the battery for the Roomba 692 prior to removal.
Remember to review the iRobot Roomba 692 Troubleshooting Page before attempting any maintenance or repairs on your vacuum.
O que você precisa
To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
Remove two gold 12 mm screws from the motor, and lift the motor out.
