Ir para o conteúdo principal
iRobot Roomba 690 Battery Replacement
O que você precisa
    1. iRobot Roomba 690 Battery Replacement, Spinning Brush: passo 1, imagem 1 %32
      • Place the Roomba upside down so that the wheels and brushes are facing upward.
      Pergunte ao FixBot
      Comentar
    2. iRobot Roomba 690 Battery Replacement: passo 2, imagem 1 %32 iRobot Roomba 690 Battery Replacement: passo 2, imagem 2 %32 iRobot Roomba 690 Battery Replacement: passo 2, imagem 3 %32
      • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
      • Remove the spinning brush from the vacuum.
      Pergunte ao FixBot
      Comentar
    1. iRobot Roomba 690 Battery Replacement, Battery: passo 3, imagem 1 %32
      • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
      • They are labeled with triangular arrows next to them on the cover.
      Pergunte ao FixBot
      Comentar
    2. iRobot Roomba 690 Battery Replacement: passo 4, imagem 1 %32
      • Lift the bottom cover up from the rest of the Roomba.
      Pergunte ao FixBot
      Comentar
    3. iRobot Roomba 690 Battery Replacement: passo 5, imagem 1 %32 iRobot Roomba 690 Battery Replacement: passo 5, imagem 2 %32 iRobot Roomba 690 Battery Replacement: passo 5, imagem 3 %32
      • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
John Galvin
Membro desde: 03/23/22
584 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-1, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-1, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G1
2 Membros
Autoria de 25 guias
2Comentários do guia
Thanks, super easy and great pictorial instruction.
Faythe2Faythe - Responder Compartilhar
Yes, this is very easy. Now, how about replacing the old batteries in the battery pack for new ones?
I know that it can be done but so far the experts show replacement of the sealed battery pack.
Miguel Pérez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 48
Ao todo: 1,995
