Ir para o conteúdo principal
iRobot Roomba 650 Caster Wheel Replacement
O que você precisa
    1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: passo 1, imagem 1 %32 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: passo 1, imagem 2 %32
      • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
      • Set the screw aside and pull the brush out.
      Pergunte ao FixBot
      Comentar
    2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: passo 2, imagem 1 %32 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: passo 2, imagem 2 %32
      • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
      • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
      • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
      Pergunte ao FixBot
      Comentar
    1. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: passo 3, imagem 1 %32
      • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
      Pergunte ao FixBot
      Comentar
    2. iRobot Roomba 650 Caster Wheel Replacement: passo 4, imagem 1 %32 iRobot Roomba 650 Caster Wheel Replacement: passo 4, imagem 2 %32
      • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
      Pergunte ao FixBot
      Comentar
Conclusão
Alex Schnorr
Membro desde: 01/22/15
649 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-7, Maness Winter 2015 Membro de Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Membros
Autoria de 12 guias
3Comentários do guia
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - Responder Compartilhar
Worked for my 690 as well.
Luke Oliver - Responder Compartilhar
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 2,692
