Ir para o conteúdo principal
iRobot Braava 375t Motherboard Replacement
O que você precisa
  1. iRobot Braava 375t Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 iRobot Braava 375t Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Flip device over.
    • Remove the cleaning cloth compartment on the bottom to access screws.
  2. iRobot Braava 375t Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four bottom cover screws.
  3. iRobot Braava 375t Motherboard Replacement: passo 3, imagem 1 %32
    • Flip the device back over and remove the shell by unplugging the wire that is holding the shell to the motherboard.
  4. iRobot Braava 375t Motherboard Replacement: passo 4, imagem 1 %32
    • Disconnect the rest of the wires and remove all screws that are attached to the motherboard.
    • To remove the wires, disconnect the plastic pins in a similar fashion to the ones in the Battery Replacement guide.
  5. iRobot Braava 375t Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the zip ties holding the wires together using a sharp object or thin scissors.
    • If you do not have pliers or a wire cutter available, then you can use the heads of thin screwdrivers to wedge the zip ties enough to remove them.
Conclusão
Uma outra pessoa concluiu este guia.
Angel Ledezma
Membro desde: 09/26/22
133 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
Membros da 6
Autoria de 4 guias
Um comentário
How long does this guide take?
Chris Yepez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 154
