Ir para o conteúdo principal
iRobot Braava 375t Battery Replacement
O que você precisa
    1. iRobot Braava 375t Battery Replacement, Battery: passo 1, imagem 1 %32
      • Turn the device over upside down and locate the battery panel.
      • The panel has a symbol of a trash can crossed out.
      Pergunte ao FixBot
      Comentar
    2. iRobot Braava 375t Battery Replacement: passo 2, imagem 1 %32
      • After locating the panel, locate the screw (should be around the top center).
      • You will need a medium sized flathead screwdriver to loosen the screw.
      Pergunte ao FixBot
      Comentar
    3. iRobot Braava 375t Battery Replacement: passo 3, imagem 1 %32
      • Insert the screwdriver and turn counter clockwise (left) to loosen the screw.
      • You may need to apply pressure when turning if the screw is tight.
      Pergunte ao FixBot
      Comentar
    4. iRobot Braava 375t Battery Replacement: passo 4, imagem 1 %32 iRobot Braava 375t Battery Replacement: passo 4, imagem 2 %32
      • Once the screw is completely taken off, remove the panel to reveal the battery.
      • The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
      • Use a small screwdriver and wedge the head between the clips if the pins are tight.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 445
