Ir para o conteúdo principal
iRobot Braava 320 Battery Replacement
O que você precisa
    1. iRobot Braava 320 Battery  Replacement, Battery: passo 1, imagem 1 %32
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      Pergunte ao FixBot
      Comentar
    2. iRobot Braava 320 Battery  Replacement: passo 2, imagem 1 %32
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      Pergunte ao FixBot
      Comentar
    3. iRobot Braava 320 Battery  Replacement: passo 3, imagem 1 %32 iRobot Braava 320 Battery  Replacement: passo 3, imagem 2 %32
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S1-G3, Nance Spring 2017 Membro de USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membros
Autoria de 20 guias
1Comentário do guia
where do I get a new battery from?
j.svetlova - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 5,176
