Ir para o conteúdo principal
iPod 3rd Generation Hard Drive Cable Replacement
O que você precisa
  1. iPod 3rd Generation Hard Drive Cable Replacement, Case: passo 1, imagem 1 %32
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
    Pergunte ao FixBot
    Comentar
  2. iPod 3rd Generation Hard Drive Cable Replacement: passo 2, imagem 1 %32 iPod 3rd Generation Hard Drive Cable Replacement: passo 2, imagem 2 %32 iPod 3rd Generation Hard Drive Cable Replacement: passo 2, imagem 3 %32
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should open easily.
    Pergunte ao FixBot
    Comentar
  3. iPod 3rd Generation Hard Drive Cable Replacement: passo 3, imagem 1 %32
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
    Pergunte ao FixBot
    Comentar
  4. iPod 3rd Generation Hard Drive Cable Replacement: passo 4, imagem 1 %32 iPod 3rd Generation Hard Drive Cable Replacement: passo 4, imagem 2 %32
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
    Pergunte ao FixBot
    Comentar
  5. iPod 3rd Generation Hard Drive Cable Replacement, Hard Drive Cable: passo 5, imagem 1 %32
    • Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
    Pergunte ao FixBot
    Comentar
  6. iPod 3rd Generation Hard Drive Cable Replacement: passo 6, imagem 1 %32
    • Peel back the metallic tape connecting the hard drive ribbon to the blue mounting bracket.
    Pergunte ao FixBot
    Comentar
  7. iPod 3rd Generation Hard Drive Cable Replacement: passo 7, imagem 1 %32
    • Use a spudger to carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    Pergunte ao FixBot
    Comentar
  8. iPod 3rd Generation Hard Drive Cable Replacement: passo 8, imagem 1 %32
    • Lift the hard drive mounting bracket and cable off the hard drive.
    Pergunte ao FixBot
    Comentar
  9. iPod 3rd Generation Hard Drive Cable Replacement: passo 9, imagem 1 %32
    • Peel up the metallic tape holding the hard drive ribbon to the blue mounting bracket.
    Pergunte ao FixBot
    Comentar
  10. iPod 3rd Generation Hard Drive Cable Replacement: passo 10, imagem 1 %32
    • Peel up the black tape securing the hard drive ribbon to the mounting bracket.
    • The hard drive ribbon is now free from the iPod.
    Pergunte ao FixBot
    Comentar
Conclusão
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 85
Ao todo: 10,929
