Ir para o conteúdo principal
iPhone XS Pentalobe Screws Replacement
O que você precisa
  1. iPhone XS Pentalobe Screws Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusão
15 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
439.280 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
2 comentários
So you have not explained wether or not the iphone XS and the iphone X have identical pentalobe screws, what a guide it is, well infact i found out the hard way they are identical and replaceable with iphone x housing pentalobe screws, thanks.
Jonez K - Responder
On the screws what is the black stuff at the end of the screws? Because it came off my screws now I’m concerned that I have compromised the waterproof ness of my phone
Casey Hunter - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 114
Duração total: 14,577
