Ir para o conteúdo principal
iPhone Camera Repair
O que você precisa
Vídeo de Apresentação
  1. iPhone Camera Repair, main camera: passo 1, imagem 1 %32 iPhone Camera Repair, main camera: passo 1, imagem 2 %32
    • Today, REWA LAB will share with you a repair case of an iPhone camera and walk you through some knowledge of iPhone camera repair.
    • Open the phone camera. When taking photos with the wide-angle camera, cracks appear. The ultra-wide camera works fine. We can judge that the optical filter of the wide-angle camera is damaged.
    Pergunte ao FixBot
    Comentar
  2. iPhone Camera Repair: passo 2, imagem 1 %32 iPhone Camera Repair: passo 2, imagem 2 %32 iPhone Camera Repair: passo 2, imagem 3 %32
    • We can judge that the optical filter of the wide-angle camera is damaged. Then we disassemble the phone and try to repair the camera. First of all, put the camera on the specialized Heating Platform at 100 °C.
    • When the temperature reaches 100 °C, remove black adhesive around the camera with a Sculpture Knife. Then pry up the wide-angle camera.
    • Attach the camera to the specialized holder. Before repair, apply protection tape to the camera.
    Pergunte ao FixBot
    Comentar
  3. iPhone Camera Repair: passo 3, imagem 1 %32 iPhone Camera Repair: passo 3, imagem 2 %32 iPhone Camera Repair: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Separate the camera edges with a Sculpture Knife. Next, remove the metal cover with Hot Air Gun at 120 °C.
    • Keep heating with Hot Air Gun at 120 °C. Remove black adhesive with Tweezers. Apply some Paste Flux.
    • Separate the motor from the CMOS with ultrathin Soldering Iron at 380 °C
    Pergunte ao FixBot
    Comentar
  4. iPhone Camera Repair: passo 4, imagem 1 %32 iPhone Camera Repair: passo 4, imagem 2 %32
    • It can be seen that the optical filter is broken while the motor and blue lens are good. If the motor is damaged, the camera will fail to focus or shake. A motor replacement can help you solve the problem.
    • The middle part of the motor is the blue lens. If the blue lens is damaged, the camera will become blurry. The solution is to replace the blue lens.
    • Then we replace the cracked optical filter with a new one.
    Pergunte ao FixBot
    Comentar
  5. iPhone Camera Repair: passo 5, imagem 1 %32 iPhone Camera Repair: passo 5, imagem 2 %32 iPhone Camera Repair: passo 5, imagem 3 %32
    • Apply some UV adhesive to the broken optical filter.
    • Put the new optical filter in position.
    • Solidify with a UV Lamp.
    Pergunte ao FixBot
    Comentar
  6. iPhone Camera Repair: passo 6, imagem 1 %32 iPhone Camera Repair: passo 6, imagem 2 %32 iPhone Camera Repair: passo 6, imagem 3 %32
    • Remove side adhesive with Hot Air Gun.
    • Then push the cracked optical filter out with the specialized holder.
    • Remove residual shards and black adhesive with Hot Air Gun.
    Pergunte ao FixBot
    Comentar
  7. iPhone Camera Repair: passo 7, imagem 1 %32 iPhone Camera Repair: passo 7, imagem 2 %32 iPhone Camera Repair: passo 7, imagem 3 %32
    • Then remove dust spots with a specialized swab. Please be extremely careful not to damage the CMOS during operation. If the CMOS is damaged, the camera will be unrepairable.
    • Then apply some UV adhesive and a new optical filter. Solidify with UV Lamp.
    Pergunte ao FixBot
    Comentar
  8. iPhone Camera Repair: passo 8, imagem 1 %32 iPhone Camera Repair: passo 8, imagem 2 %32 iPhone Camera Repair: passo 8, imagem 3 %32
    • Then we assemble the camera. Apply some Paste Flux around the motor. Solder the motor with the CMOS with Soldering Iron. Clean the camera with alcohol.
    • Next, we install the wide-angle camera for testing. The camera works fine. Apply B7000 to fix the wide-angle camera. That’s all for the optical filter replacement of iPhone camera.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
REWA
Membro desde: 11/24/20
19.384 Reputação
Autoria de 55 guias
2Comentários do guia
Good job! But, the cost of labor and material is not economical. It is still wise to buy the whole camera module as a replacement. Easier and more practical.
On the other hand, if the viewer opted to do the filter replacement, this is a great reference since Rewa is a reputable company. Thank you for sharing this useful guide.
Jojo - Responder Compartilhar
Incrível! Parabéns!!
Daan.ll - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 131
Últimos 30 dias: 872
Ao todo: 31,910
