Ir para o conteúdo principal
Logic Board Connectors
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Logic Board Connectors, Disconnect the logic board: passo 1, imagem 1 %32 Logic Board Connectors, Disconnect the logic board: passo 1, imagem 2 %32
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Logic Board Connectors: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Standoff Screwdriver for iPhones
    $5.49
    Comprar
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Logic Board Connectors: passo 3, imagem 1 %32
    • Remove the rear-facing camera bracket.
  4. Logic Board Connectors: passo 4, imagem 1 %32 Logic Board Connectors: passo 4, imagem 2 %32
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Logic Board Connectors: passo 5, imagem 1 %32
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Logic Board Connectors: passo 6, imagem 1 %32
    • Remove the upper cable bracket.
  7. Logic Board Connectors: passo 7, imagem 1 %32 Logic Board Connectors: passo 7, imagem 2 %32
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Logic Board Connectors, Remove the top left antenna component: passo 8, imagem 1 %32
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Logic Board Connectors: passo 9, imagem 1 %32
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Logic Board Connectors: passo 10, imagem 1 %32
    • Remove the antenna component.
  11. Logic Board Connectors, Remove the top left grounding clip: passo 11, imagem 1 %32
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Logic Board Connectors: passo 12, imagem 1 %32
    • Remove the grounding clip.
  13. Logic Board Connectors, Unscrew the logic board: passo 13, imagem 1 %32
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Logic Board Connectors: passo 14, imagem 1 %32 Logic Board Connectors: passo 14, imagem 2 %32
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Logic Board Connectors: passo 15, imagem 1 %32 Logic Board Connectors: passo 15, imagem 2 %32
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Conclusão
Arthur Shi
Membro desde: 01/03/18
252.833 Reputação
Autoria de 526 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 207
