Introdução
This guide demonstrates a professional-level repair requiring advanced tools. With this special back glass separator, a broken iPhone 8/8P/X back glass can be removed in just 3 minutes. Residual glue can also be removed easily, which is convenient for subsequent attaching of a new back glass.
Vídeo de Apresentação
Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
15 outras pessoas executaram este guia.
1Comentário do guia
Where does it show the replacement I only see the removal?
