Ir para o conteúdo principal
iPhone 5 LCD Shield Plate Replacement
O que você precisa
  1. iPhone 5 LCD Shield Plate Replacement, Taping the display glass: passo 1, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, Taping the display glass: passo 1, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement, Taping the display glass: passo 1, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 LCD Shield Plate Replacement, Remove the Pentalobe screws: passo 2, imagem 1 %32
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 LCD Shield Plate Replacement, How to prevent display separation: passo 3, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, How to prevent display separation: passo 3, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement, How to prevent display separation: passo 3, imagem 3 %32
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 LCD Shield Plate Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 5 LCD Shield Plate Replacement: passo 5, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement: passo 5, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPhone 5 LCD Shield Plate Replacement, Manual Opening Procedure: passo 6, imagem 1 %32
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 LCD Shield Plate Replacement, Start lifting the front panel assembly: passo 7, imagem 1 %32
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 LCD Shield Plate Replacement, Detaching the front panel side clips: passo 8, imagem 1 %32
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 LCD Shield Plate Replacement, Opening up the phone: passo 9, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, Opening up the phone: passo 9, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement, Opening up the phone: passo 9, imagem 3 %32
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 LCD Shield Plate Replacement, Removing the battery connector bracket screws: passo 10, imagem 1 %32
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 LCD Shield Plate Replacement, Removing the battery connector bracket: passo 11, imagem 1 %32
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 LCD Shield Plate Replacement, Disconnecting the battery connector: passo 12, imagem 1 %32
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  13. iPhone 5 LCD Shield Plate Replacement, Removing the front panel assembly cable bracket screws: passo 13, imagem 1 %32
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 LCD Shield Plate Replacement, Removing the front panel assembly cable bracket: passo 14, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, Removing the front panel assembly cable bracket: passo 14, imagem 2 %32
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 LCD Shield Plate Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 2 %32 iPhone 5 LCD Shield Plate Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5 LCD Shield Plate Replacement, Separating front panel assembly and rear case: passo 16, imagem 1 %32
    • Remove the front panel assembly from the rear case.
  17. iPhone 5 LCD Shield Plate Replacement, LCD Shield Plate: passo 17, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement, LCD Shield Plate: passo 17, imagem 2 %32
    • Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total).
  18. iPhone 5 LCD Shield Plate Replacement: passo 18, imagem 1 %32
    • Remove the following two screws securing the LCD shield plate to the display assembly:
    • Single 2.6 mm Phillips screw
    • Single 1.4 mm Phillips screw
  19. iPhone 5 LCD Shield Plate Replacement: passo 19, imagem 1 %32 iPhone 5 LCD Shield Plate Replacement: passo 19, imagem 2 %32
    • Remove the LCD shield plate from the display assembly.
Conclusão
124 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
514.567 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
125 Membros
Autoria de 25.369 guias
3Comentários do guia
any number that i can call, am having problem with returns to the initial conditions.
idham - Responder Compartilhar
On Steps 17 and 18 you somehow magically removed the ear speaker/ ff camera bracket. You do need to remove that before you can take the lcd plate off.
Damon - Responder Compartilhar
Still have not corrected the missing instructions involving removing the earpiece speaker… magical
Ethan LaMoure - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 83
Ao todo: 164,034
