Ir para o conteúdo principal
iPhone 14 Pro Max SIM Card Replacement
O que você precisa
  1. iPhone 14 Pro Max SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 iPhone 14 Pro Max SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 2 %32 iPhone 14 Pro Max SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 3 %32
    • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 14 Pro Max SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 1 %32 iPhone 14 Pro Max SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 2 %32 iPhone 14 Pro Max SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 3 %32
    • Remove the SIM card tray from the iPhone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
Conclusão
10 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
228.969 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
6 comentários
Yo Dom, no removable SIM card carrier on 14-pro-max (e-sim only).
mrmichaelpeters - Responder
Hi mrmichaelpeters,
only the US model does not offer a physical SIM card tray, however the international model A2894 has one.
Dominik Schnabelrauch -
Hello, can I swap sim card trays from iPhone 13 256 Green to iPhone 14 Pro Max 128 Black (A2894) in EUROPE? I’m guessing they have the same sim card tray shape, I don’t care about the color. Thanks
Stefano Valero - Responder
i mean apple sim tray has not changed size so yeah you can
Shuch Up -
My hands started hurting in pain. i suffered how how this was. the phone exploded and then my house caught on fire. i blamed this all on apple and decided to hack their severs. thats why iphones suck now. because this super hard task >:( (Note this is a joke and I did this myself and it was a quite easy task thank you for this tutorial.)
Blake - Responder
It's an e sim how do I do it
Victory Onyeka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 100
Últimos 30 dias: 388
Duração total: 15,468
