Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPad Pro 13", use o nosso manual de serviço.
    1. iPad Pro 13" Chip ID, Main Board Side 1: passo 1, imagem 1 %32 iPad Pro 13" Chip ID, Main Board Side 1: passo 1, imagem 2 %32
      • Apple APL1206/339S01449 S Apple M4 deca-core applications processor
      • Micron MT62F768M64D4AS-026 XT:B 6 GB LPDDR5X SDRAM memory
      • Kioxia K5A4RE0344CA12329 256 GB NAND flash
      • STMicroelectronics ST33J secure microcontroller
      • Apple APL1066/343S00682 power management
      • Apple APL1067/343S00683 power management
      • Analog Devices MAX98709B audio amplifier
      Pergunte ao FixBot
      Comentar
    2. iPad Pro 13" Chip ID: passo 2, imagem 1 %32
      • Texas Instruments SN25A23 USB type-C controller
      • Winbond W25Q80DV 1 MB serial NOR flash memory
      • Likely Apple U0MAR9-Y7 Thunderbolt 3 controller
      • Winbond W25Q64NE 8 MB serial NOR flash memory
      • Likely Broadcom BCM15900B0 touchscreen controller
      • Likely Broadcom BCM15957A0 touchscreen controller
      • Qualcomm PMX65-000 power management
      Pergunte ao FixBot
      Comentar
    3. iPad Pro 13" Chip ID: passo 3, imagem 1 %32
      • Qualcomm QET7100-001 envelope tracker
      • Apple 343S00613-A0 power management
      • Likely Apple 343S00377 power management
      • Likely Qualcomm clock generator
      • Texas Instruments TPS61230A 5 V / 6 A step-up converter
      • Texas Instruments TPS61022 8 A boost converter
      • Texas Instruments TPS259814L 6 mΩ eFuse
      Pergunte ao FixBot
      Comentar
    4. iPad Pro 13" Chip ID, Main Board Side 1 - Connectivity: passo 4, imagem 1 %32
      • Qualcomm SDX70M-000 Snapdragon X70 modem
      • Qualcomm SDR735-001 RF transceiver
      • Skyworks SKY58440-11 front-end module
      • Broadcom AFEM-8233 front-end module
      • Skyworks SKY50313 ? front end module
      • Apple 339S01360 WiFi & Bluetooth module
      Pergunte ao FixBot
      Comentar
    5. iPad Pro 13" Chip ID, Main Board Side 1 - Sensors: passo 5, imagem 1 %32
      • Bosch Sensortec accelerometer & gyroscope
      • Bosch Sensortec pressure sensor
      Pergunte ao FixBot
      Comentar
    6. iPad Pro 13" Chip ID, Camera Board Side 1: passo 6, imagem 1 %32 iPad Pro 13" Chip ID, Camera Board Side 1: passo 6, imagem 2 %32
      • Apple 338S00990-A1 power management
      • Texas Instruments LM3567A1 LED flash driver
      Pergunte ao FixBot
      Comentar
    7. iPad Pro 13" Chip ID, Wireless Charging Board Side 1: passo 7, imagem 1 %32 iPad Pro 13" Chip ID, Wireless Charging Board Side 1: passo 7, imagem 2 %32
      • Likely NXP Semiconductor wireless charging controller
      • Texas Instruments TPS62825 2 A step-down converter
      Pergunte ao FixBot
      Comentar
1Comentário do guia
Good technical detailing
Lokesh Ram - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 148
Ao todo: 10,571
