Introdução
Use this guide to replace the bottom speaker in your iPad mini 6.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You'll need replacement adhesive in order to complete this repair.
Use the point of spudger to pry up and disconnect the bottom speaker's cable.
Apply a heated iOpener to the bottom-left edge of the device to loosen the bottom speaker's adhesive.
Adhesive is located around the perimeter of the speaker.
Adhesive is also located in the center of the speaker.
Insert an opening pick between the bottom speaker and the frame.
Pry up with the opening pick to completely separate the bottom speaker from the frame.
Remove the bottom speaker.
