Introdução
Use this guide to remove and replace the battery in your iPad Mini 3 Wi-Fi.
If your battery is swollen, take appropriate precautions.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Remove the following Phillips #00 screws from the display cable bracket:
One 2.8 mm screw
Three 1.4 mm screws
Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
Heat an iOpener and place it in the center of the back of the iPad case.
After about two minutes, remove the iOpener and place it on the right side of the iPad—the side farthest from the camera.
16 outras pessoas concluíram este guia.
4 comentários
Thank you so much I really needed help
Thanks, Sam
Thank you! I had an iPad Mini 3 with a bulging battery that had lifted the glass and display away from the body of the iPad. I purchased the repair kit + battery replacement kit and was able to install the new battery using these instructions. I took extra time to make sure the glass and display were not damaged from the bulging battery, but it made it a little easier to get the glass off since most of the adhesive had already been lifted off. I used Goo Gone and one of the blue plastic spudgers to remove the old adhesive from the glass and from the case.
I would have liked to have seen instructions on installing the replacement adhesive but figured it out. I cut some of the long pieces into smaller pieces to make it more manageable, especially the section under the digitizer ribbon. Also, there wasn’t a mention of the two, small, metal pieces that stick to the adhesive in two of the corners to help support the glass over the display screws. I made sure to save those and replace them.
My Ipad Mini 3 doesn’t turn on at all. I checked the battery’s voltage and it’s ok. Could it be the LCD? Can anyone help me?
