Introdução
Use this guide to replace the right-hand antenna, the GPS antenna, in your iPad Mini 2 Wi-Fi.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Remove the following Phillips #00 screws from the display cable bracket:
One 2.7 mm screw
Two 1.4 mm screws
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
Use the tip of a spudger to peel the tape off of the antenna cables near the logic board.
Remove the following Phillips #00 screws from the right antenna:
Three 1.5 mm screws
One 2.6 mm screw
2 outras pessoas concluíram este guia.
Um comentário
Thanks so much for your guide! I actually completed it. However, even though I changed out the antenna, my wi-fi and bluetooth still don't work. I think it's probably a wi-fi logic board issue. sigh.
One thing I would add to this guide or anyone attempting to complete it would be to wear gloves while handling the LCD and screen plate! I slightly touched the LCD and it was a pain trying to get my fingerprints off of it without smearing.
Also, steps 44-46 were a bit different on my iPad Mini 2 64GB version. Not sure why, but some things were different internally. So I kind of had to wing it and just use my own gut judgment that I was removing and adjusting the parts correctly. But after that I was fine.
Thanks for the guide. Since the logic board is $100 to replace, I just purchased a new iPad and am going to sell my broken one for parts.
