Introdução
Use this guide to fix your iPad Mini 2 screen. This guide will show you how to replace the front panel, including digitizer, home button, and display glass on your iPad Mini 2 Wi-Fi.
O que você precisa
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Remove the following Phillips #00 screws from the display cable bracket:
One 2.7 mm screw
Two 1.4 mm screws
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
On the replacement front panel, remove the small piece of adhesive backing from the digitizer cable.
Fold the digitizer cable back over onto itself and press firmly to secure the adhesive.
Peel the large clear plastic liner off of the inside of the glass.
Peel any blue plastic backings covering the adhesive around the perimeter of the front panel assembly.
Don't remove any copper coverings from the outlined region, such as yellow kapton tape or black electrical tape.
Ensure the glass panel is free of fingerprints and grime before installing it on your device.
Place the edge of a plastic opening tool on each side of the magnet near the top left corner of the front panel assembly.
Carefully wedge the edge of the right plastic opening tool underneath the magnet.
Wedge the left plastic opening tool underneath the magnet and simultaneously pry and push it towards the right plastic opening tool.
284 outras pessoas executaram este guia.
51Comentários do guia
Step 16 through step 24
I made a mess:
- I slid the picks all around the glass breaking the glass, the antenna and digit cables.
What do I need to fix it ? I have already ordered by you a front glass and a a logic board
(LCD I have it already). What do I need more ?
Pls. Help
Sergio Ungaro
Hey, I have a big problem.
I did all this steps and everything was fine so i put it together. Now I have a ghost-touch if i press the margin at the right edge. I didn't remove the yellow stripe and i thing the cable is not between the frame and the metal.
thx
Had the same issue. Just use Kapton tape and cover the bottom part of the ipad where the Home button is. What’s causing the issue is grounding thus the ghost touch. Search or “Ipad mini ghost touch kapton” on YouTube. Hope this helps.
THE LCD SCREEN IS EXTREMELY FRAGILE
you will crack it with the slightest bend. This is crucial as you try to free it from the STRONG adhesive tape at the bottom speakers. This tutorial has no mention of how careful you have to be with the LCD, or how much stronger the adhesion is in this area, but then again, you can always purchase a new LCD from iFixit, riiiiight?
Good info! Thanx
thomas -
