Ir para o conteúdo principal
iPad Display Assembly 4 Pc. Adhesive Application
O que você precisa
    1. iPad Display Assembly 4 Pc. Adhesive Application, iPad Display Assembly 4 Pc. Adhesive Application: passo 1, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application, iPad Display Assembly 4 Pc. Adhesive Application: passo 1, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
      • Use tweezers to pull up sections of tape residue.
      • Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
      • Remove the residue by wiping in one direction to prevent smearing.
      • Do not scrape with a metal tool, or you will scratch the display assembly's surface.
      Pergunte ao FixBot
      Comentar
    2. iPad Display Assembly 4 Pc. Adhesive Application: passo 2, imagem 1 %32
      • Lay out the replacement adhesive strips around the display assembly so that they correspond to the correct sides.
      Pergunte ao FixBot
      Comentar
    3. iPad Display Assembly 4 Pc. Adhesive Application: passo 3, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 3, imagem 2 %32
      • Each adhesive strip is encased in four layers of plastic—three on top and one on the bottom.
      • Peel and remove the topmost plastic cling layer from the left adhesive strip.
      • Peel and remove the bottom plastic liner from the strip.
      • The top of the adhesive strip should still be covered by a colored plastic layer as well as a clear plastic stiffening layer.
      • The bottom of the adhesive strip should now be exposed and sticky.
      Pergunte ao FixBot
      Comentar
    4. iPad Display Assembly 4 Pc. Adhesive Application: passo 4, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 4, imagem 2 %32
      • If there are extra bits of adhesive on the strips that are not required for your particular model of iPad, remove them now.
      Pergunte ao FixBot
      Comentar
    5. iPad Display Assembly 4 Pc. Adhesive Application: passo 5, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 5, imagem 2 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 5, imagem 3 %32
      • Align the left adhesive strip to the left edge of the display assembly.
      • Beginning from one corner, lay the adhesive strip onto the display assembly and press the strip into place.
      • If necessary, use a spudger to press down the narrow parts of the adhesive strip.
      Pergunte ao FixBot
      Comentar
    6. iPad Display Assembly 4 Pc. Adhesive Application: passo 6, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 6, imagem 2 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 6, imagem 3 %32
      • Repeat the process with the right adhesive strip.
      • Peel and remove the topmost cling layer from the strip.
      • Peel and remove the bottom liner layer from the strip.
      • Align the adhesive strip to the right edge of the display assembly.
      • Starting from one corner, lay the adhesive strip onto the display assembly and press in place.
      Pergunte ao FixBot
      Comentar
    7. iPad Display Assembly 4 Pc. Adhesive Application: passo 7, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 7, imagem 2 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 7, imagem 3 %32
      • Repeat the process for the top adhesive strip.
      • Peel and remove the bottom liner from the strip.
      • Align the strip to the top of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
      • Press the strip in place.
      Pergunte ao FixBot
      Comentar
    8. iPad Display Assembly 4 Pc. Adhesive Application: passo 8, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 8, imagem 2 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 8, imagem 3 %32
      • Repeat the process for the bottom adhesive strip.
      • Align the strip to the bottom of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
      Pergunte ao FixBot
      Comentar
    9. iPad Display Assembly 4 Pc. Adhesive Application: passo 9, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 9, imagem 2 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 9, imagem 3 %32
      • Peel and remove the clear plastic stiffening layer from all four adhesive strip sections.
      Pergunte ao FixBot
      Comentar
    10. iPad Display Assembly 4 Pc. Adhesive Application: passo 10, imagem 1 %32
      • Continue with the reassembly process until you are ready to seal the device.
      Pergunte ao FixBot
      Comentar
    11. iPad Display Assembly 4 Pc. Adhesive Application: passo 11, imagem 1 %32 iPad Display Assembly 4 Pc. Adhesive Application: passo 11, imagem 2 %32
      • Peel and remove the four colored plastic liners to expose the adhesive.
      • Close the device and place something heavy, such as a stack of large books, on top for thirty minutes to help the new adhesive bond.
      • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
Tarun Thiruma
Membro desde: 11/20/19
40.468 Reputação
Autoria de 134 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 81
Ao todo: 3,286
