Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPad ClamCase, use o nosso manual de serviço.
    1. iPad ClamCase, iPad ClamCase: passo 1, imagem 1 %32 iPad ClamCase, iPad ClamCase: passo 1, imagem 2 %32
      • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
      • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
      • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
      Pergunte ao FixBot
      Comentar
    2. iPad ClamCase: passo 2, imagem 1 %32 iPad ClamCase: passo 2, imagem 2 %32
      • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
      • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
      Pergunte ao FixBot
      Comentar
    3. iPad ClamCase: passo 3, imagem 1 %32 iPad ClamCase: passo 3, imagem 2 %32
      • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
      • Be patient, the thin black covering might be really stuck to the bottom.
      Pergunte ao FixBot
      Comentar
    4. iPad ClamCase: passo 4, imagem 1 %32
      • Once the thin black covering is removed, you will see 15 screws.
      • Use the T6 Torx screwdriver to remove the screws.
      Pergunte ao FixBot
      Comentar
    5. iPad ClamCase: passo 5, imagem 1 %32
      • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
      Pergunte ao FixBot
      Comentar
    6. iPad ClamCase: passo 6, imagem 1 %32
      • You are done.
      Pergunte ao FixBot
      Comentar
2Comentários do guia
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Responder Compartilhar
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 45
Ao todo: 8,252
