Ir para o conteúdo principal
iPad Air 3 Screen Replacement
O que você precisa
  1. iPad Air 3 Screen Replacement, Screen: passo 1, imagem 1 %32 iPad Air 3 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Cracked near home button its important to not break home button flex cable
    • Apply heat to the screen! Do NOT SKIP THIS STEP
    • Make sure to turn it off if you can to prevent breaking the backlight filter
    • Pry with splicer around the edges
    • Display cables are on the bottom of screen opening up like an upside-down note pad
  2. iPad Air 3 Screen Replacement: passo 3, imagem 1 %32
    • Lift from the top like so
    • Display Cables
  3. iPad Air 3 Screen Replacement: passo 4, imagem 1 %32 iPad Air 3 Screen Replacement: passo 4, imagem 2 %32 iPad Air 3 Screen Replacement: passo 4, imagem 3 %32
    • Set screen up a little bit to get to power connection
    • Power connection has PH000 screw holding it together
    • Slide a card under connection
    • Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
  4. iPad Air 3 Screen Replacement: passo 5, imagem 1 %32 iPad Air 3 Screen Replacement: passo 5, imagem 2 %32
    • Lift display back up to get to the display cables
    • Unscrew 2 PH000 Screws from display cable bracket
    • Use the flat end of plastic spudger to lift off connections
    • There is 4 flex cables that need disconnecting
  5. iPad Air 3 Screen Replacement: passo 6, imagem 1 %32 iPad Air 3 Screen Replacement: passo 6, imagem 2 %32 iPad Air 3 Screen Replacement: passo 6, imagem 3 %32
    • Whoohoo we got it off now clean the edges for any broken glass
    • Keep track of rubbers covering proximity light sensor on the top
    • Light covers place on top of proxmity sensors
  6. iPad Air 3 Screen Replacement: passo 7, imagem 1 %32 iPad Air 3 Screen Replacement: passo 7, imagem 2 %32 iPad Air 3 Screen Replacement: passo 7, imagem 3 %32
    • APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
    • If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
    • Take of home button flex cover
    • Use flat end of spudger to pry up home button flex connector
  7. iPad Air 3 Screen Replacement: passo 8, imagem 1 %32 iPad Air 3 Screen Replacement: passo 8, imagem 2 %32 iPad Air 3 Screen Replacement: passo 8, imagem 3 %32
    • Reapply heat if you spent to much time getting flex unhooked
    • Pry with splicer under the home button bracket car
    • Clean glass around gasket
  8. iPad Air 3 Screen Replacement: passo 9, imagem 1 %32 iPad Air 3 Screen Replacement: passo 9, imagem 2 %32
    • Install home button on new screen I recommend using liquid adhesive for this!
    • Push the home button a couple of times to make sure it stills on and make sure it is clicking!
  9. iPad Air 3 Screen Replacement: passo 10, imagem 1 %32 iPad Air 3 Screen Replacement: passo 10, imagem 2 %32
    • Connect all 4 Flex cables to the logic board!
    • Now at the bottom of the new screen screw in the battery connection to test the new screen!
  10. iPad Air 3 Screen Replacement: passo 11, imagem 1 %32
    • Test screen drawing on the notes make sure it works!
    • Adhere new screen with preinstalled adhesive and clap it!
Linha de Chegada
Mark D Schlossman
Membro desde: 09/25/19
5.603 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 36
Duração total: 340
