Ir para o conteúdo principal
iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement
O que você precisa
  1. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement, Display: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    iMac Intel 27" Cardboard Service Wedge
    Comprar
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
  2. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 2, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 2, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 2, imagem 3 %32
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
  3. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 3, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 3, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 3, imagem 3 %32
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 4, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 4, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 4, imagem 3 %32
    • Continue wheeling the tool up around the top left corner.
  5. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 5, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 5, imagem 2 %32
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 6, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 6, imagem 2 %32
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 7, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 7, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 7, imagem 3 %32
    • Push the tool around the top right corner of the display.
  8. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 8, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 8, imagem 2 %32
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 9, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 9, imagem 2 %32
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 10, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 10, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 10, imagem 3 %32
    Plastic Cards
    $2.99
    Comprar
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
  11. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 11, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 11, imagem 2 %32
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  12. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 12, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 12, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 12, imagem 3 %32
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
  13. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 13, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 13, imagem 2 %32
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 14, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 14, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 14, imagem 3 %32
    • Insert a second card into the gap between the display and frame in the top left corner.
  15. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 15, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 15, imagem 2 %32
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  16. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 16, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 16, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 16, imagem 3 %32
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 17, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 17, imagem 2 %32
    • Insert the card back into the top left corner.
  18. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 18, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 18, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 18, imagem 3 %32
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
  19. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 19, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 19, imagem 2 %32
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 20, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 20, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 20, imagem 3 %32
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
  21. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 21, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 21, imagem 2 %32
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
  22. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 22, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 22, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 22, imagem 3 %32
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  23. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 23, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 23, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 23, imagem 3 %32
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
  24. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 24, imagem 1 %32
    • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
  25. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement, Right Speaker: passo 25, imagem 1 %32
    • Remove two 10.0 mm T10 screws.
  26. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 26, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 26, imagem 2 %32
    • Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
  27. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 27, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 27, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 27, imagem 3 %32
    • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
    • Pull the connector to the right to remove it from its socket.
  28. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 28, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 28, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 28, imagem 3 %32
    • Lift the speaker straight up and remove it from the iMac.
  29. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 29, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 29, imagem 2 %32
    • Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables—from left to right on the card, the antennas are connected in the following order:
    • Leftmost
    • Top
    • Upper right
    • Lower right
  30. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 30, imagem 1 %32
    • Remove two 3.7 mm T5 screws securing the AirPort/Bluetooth card to the logic board.
  31. iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 31, imagem 1 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 31, imagem 2 %32 iMac Intel 27" Retina 5k Display AirPort/Bluetooth Card Replacement: passo 31, imagem 3 %32
    • To avoid damaging its socket, do not push the end of the AirPort/Bluetooth Card away from the logic board excessively.
    • Push the end of the AirPort/Bluetooth Card slightly toward the rear case and pull it straight out of its socket on the logic board.
    • When reinstalling the card, be sure it is properly seated before reinstalling its retaining screw.
Conclusão
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
8 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.870 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.228 guias
2 comentários
Can this Airport Card be upgraded to the iMac 2017 card with BT 4.2?
George - Responder
Out of curiosity I'm going to try to install 653-00011 card (frim iMac 2017 5k) to Late 2015 iMac 5k, will keep you informed here
andy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 32
Últimos 30 dias: 130
Duração total: 13,053
