Ir para o conteúdo principal
iMac Intel 27" EMC 2546 RAM Replacement
O que você precisa
  1. iMac Intel 27" EMC 2546 RAM Replacement, Open the RAM door: passo 1, imagem 1 %32 iMac Intel 27" EMC 2546 RAM Replacement, Open the RAM door: passo 1, imagem 2 %32
    • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
    • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
  2. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: passo 2, imagem 1 %32 iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: passo 2, imagem 2 %32 iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: passo 2, imagem 3 %32
    • Pull the RAM access door off the back of the iMac.
  3. iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: passo 3, imagem 1 %32 iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: passo 3, imagem 2 %32 iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: passo 3, imagem 3 %32
    • The RAM tray is locked into its upright position with two grey tabs.
    • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
    • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
  4. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: passo 4, imagem 1 %32 iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: passo 4, imagem 2 %32 iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: passo 4, imagem 3 %32
    • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
    • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
    • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
    • Re-insert the RAM access door back into its place.
Conclusão
56 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
494.717 Reputação
407 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
141 Membros
17.643 Guias de autoria
3 comentários
If you have two original RAM sticks, they're installed in alternating slots, so there's no need to move anything around to install two more - just use the empty slots.
matt - Responder
Ich habe diese Anleitung genutzt bei meinem 27“ late 2013 Mac. Zu den vorhandenen Speichern von 2x4GB habe ich in die leeren Slots je einen 8GB Speicher eingesetzt. Das ging problemlos so wie beschrieben. Habe kein Werkzeug gebraucht. Die Taste zum Öffnen konnte ich mit dem Daumennagel hineindrücken. Der gesamte Speicher wird mit 24GB angezeigt. Vielen Dank für diese Hilfe!
Nedra - Responder
Hello. My Imac (27-inch, Late 2012) has the original memory (2x4GB Elpida) in slots 1 and 2. When trying to install in slots 1+3, 1+4, 2+3, 2+4 it beeps three times and the Mac does not start. Replacing the original memory in slots 1+2 with new memory (2x8GB) is successful. Can not add memory to slots 3 and 4 (old memory or new). Please advise where to look for the problem.
Олег Б. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 37
Últimos 30 dias: 208
Duração total: 45,713
