Introdução
This guide will help you replace the glass panel.
O que você precisa
Ferramenta utilizada neste passo:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
24 outras pessoas executaram este guia.
