Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Follow the steps in this guide to replace the front panel in a 21.5" Retina 4K Late 2015 iMac.
This procedure involves removing the faulty/broken display, as well as transferring the display data cable and thermal sensor to a new display.
O que você precisa
Ferramenta utilizada nesse passo:iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use your fingernail or the pointed tip of a spudger to flip up the retaining flap on the display data connector.
19 outras pessoas executaram este guia.
8 comentários
Hello, I damages my iMac 2833 screen cable with mistake, I tried to find one compatible with this type but I didn't find one, c an you advise me how to find one or even repair the cable because the the wider end not damage but the other end... thanks in advance to your help...
Hi,
I am in need of a display data cable as shown above for the iMac 21.5” Late 2015. Anyone know where I can order one? Finding one on the interent is awfully confusing in identifying the correct cable.
Thanks.
See step 20 above for the display data cable needed.
Hola saludos excelente artículo los felicito. Tengo una duda. Mi IMac de. 21.5 Inch 4K sufrió un golpe en la parte superior de la pantalla. Luego del impacto la pantalla sigue funcionando normalmente, pero el glass está con grietas y astillado. Es necesario cambiarlo todo? O existe un repuesto solo del glass. Gracias por su orientacion
