Introdução
Upgrade your hard drive for more storage capacity.
O que você precisa
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the following three screws:
One shouldered 12.4 mm Phillips.
Two 7 mm T10 Torx.
My model have 3 phillips screws, no torx
Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
Remove the two 15 mm shouldered T10 Torx screws from the hard drive and remove the bracket.
149 outras pessoas executaram este guia.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Responder
