Ir para o conteúdo principal
iMac G5 17" Model A1058 RAM Replacement
O que você precisa
  1. iMac G5 17" Model A1058 RAM Replacement, Rear Panel: passo 1, imagem 1 %32
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
    Pergunte ao FixBot
    Comentar
  2. iMac G5 17" Model A1058 RAM Replacement: passo 2, imagem 1 %32 iMac G5 17" Model A1058 RAM Replacement: passo 2, imagem 2 %32 iMac G5 17" Model A1058 RAM Replacement: passo 2, imagem 3 %32
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
    Pergunte ao FixBot
    Comentar
  3. iMac G5 17" Model A1058 RAM Replacement, RAM: passo 3, imagem 1 %32 iMac G5 17" Model A1058 RAM Replacement, RAM: passo 3, imagem 2 %32 iMac G5 17" Model A1058 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Rotate each of the two RAM retaining arms away from the RAM chip.
    • Pull the RAM chip straight away from its socket.
    • Repeat this process for the other RAM chip.
    • Be sure the RAM arms are fully rotated away from the RAM socket before reinstalling any RAM chips.
    Pergunte ao FixBot
    Comentar
Conclusão
39 outras pessoas executaram este guia.
4Comentários do guia
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - Responder Compartilhar
Can i get 6 or 8 gigs ram?
frederikchalmer - Responder Compartilhar
Do both the ram slots have to have ram in them
Gary Wayne - Responder Compartilhar
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 21
Últimos 30 dias: 108
Ao todo: 31,819
