Ir para o conteúdo principal
iLive IKBC384S FM/AM Antenna Replacement
O que você precisa
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: passo 1, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: passo 1, imagem 2 %32
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: passo 2, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement: passo 2, imagem 2 %32
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: passo 3, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement: passo 3, imagem 2 %32
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: passo 4, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: passo 4, imagem 2 %32
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: passo 5, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement: passo 5, imagem 2 %32
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: passo 6, imagem 1 %32
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: passo 7, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement: passo 7, imagem 2 %32
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: passo 8, imagem 1 %32 iLive IKBC384S  FM/AM Antenna Replacement: passo 8, imagem 2 %32
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: passo 9, imagem 1 %32
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
Conclusão
Tracy Walts
Membro desde: 03/21/17
201 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membro de Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 687
