Ir para o conteúdo principal
iHome iPL8 Buttons Replacement
O que você precisa
  1. iHome iPL8  Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
    Pergunte ao FixBot
    Comentar
  2. iHome iPL8  Buttons Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
    Pergunte ao FixBot
    Comentar
  3. iHome iPL8  Buttons Replacement: passo 3, imagem 1 %32
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
    Pergunte ao FixBot
    Comentar
  4. iHome iPL8  Buttons Replacement: passo 4, imagem 1 %32 iHome iPL8  Buttons Replacement: passo 4, imagem 2 %32
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
    Pergunte ao FixBot
    Comentar
  5. iHome iPL8  Buttons Replacement, Lightning Connector: passo 5, imagem 1 %32
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
    Pergunte ao FixBot
    Comentar
  6. iHome iPL8  Buttons Replacement: passo 6, imagem 1 %32
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
    Pergunte ao FixBot
    Comentar
  7. iHome iPL8  Buttons Replacement: passo 7, imagem 1 %32 iHome iPL8  Buttons Replacement: passo 7, imagem 2 %32
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
    Pergunte ao FixBot
    Comentar
  8. iHome iPL8  Buttons Replacement: passo 8, imagem 1 %32 iHome iPL8  Buttons Replacement: passo 8, imagem 2 %32
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
    Pergunte ao FixBot
    Comentar
  9. iHome iPL8  Buttons Replacement: passo 9, imagem 1 %32 iHome iPL8  Buttons Replacement: passo 9, imagem 2 %32 iHome iPL8  Buttons Replacement: passo 9, imagem 3 %32
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
    Pergunte ao FixBot
    Comentar
  10. iHome iPL8  Buttons Replacement, Buttons: passo 10, imagem 1 %32 iHome iPL8  Buttons Replacement, Buttons: passo 10, imagem 2 %32 iHome iPL8  Buttons Replacement, Buttons: passo 10, imagem 3 %32
    • Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
    • Remove the brown button board.
    • There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
    Pergunte ao FixBot
    Comentar
  11. iHome iPL8  Buttons Replacement: passo 11, imagem 1 %32 iHome iPL8  Buttons Replacement: passo 11, imagem 2 %32
    • There are two rows of buttons clipped on to the small, circular, black columns.
    • Gently unclip the two rows of buttons and remove them.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Chen Zhong
Membro desde: 02/05/19
569 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S18-G5, Lore Winter 2019 Membro de UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 512
