Ir para o conteúdo principal
iHome iH27B iPod Adapter Replacement
O que você precisa
  1. iHome iH27B iPod Adapter Replacement, Adapter: passo 1, imagem 1 %32
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
    Pergunte ao FixBot
    Comentar
  2. iHome iH27B iPod Adapter Replacement: passo 2, imagem 1 %32
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
    Pergunte ao FixBot
    Comentar
  3. iHome iH27B iPod Adapter Replacement: passo 3, imagem 1 %32 iHome iH27B iPod Adapter Replacement: passo 3, imagem 2 %32 iHome iH27B iPod Adapter Replacement: passo 3, imagem 3 %32
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
    Pergunte ao FixBot
    Comentar
  4. iHome iH27B iPod Adapter Replacement: passo 4, imagem 1 %32 iHome iH27B iPod Adapter Replacement: passo 4, imagem 2 %32
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
    Pergunte ao FixBot
    Comentar
  5. iHome iH27B iPod Adapter Replacement: passo 5, imagem 1 %32
    • Pull out the adapter, and replace it with the new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
John Kraemer
Membro desde: 10/09/12
76 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 3-21, Amido Fall 2012 Membro de Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 42
Ao todo: 2,747
