Ir para o conteúdo principal
iHome iD95 iPod Adapter Replacement
O que você precisa
  1. iHome iD95 iPod Adapter Replacement, Backup Battery: passo 1, imagem 1 %32
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
    Pergunte ao FixBot
    Comentar
  2. iHome iD95 iPod Adapter Replacement: passo 2, imagem 1 %32
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. iHome iD95 iPod Adapter Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to take out the backup battery.
    Pergunte ao FixBot
    Comentar
  4. iHome iD95 iPod Adapter Replacement, Bottom Cover: passo 4, imagem 1 %32
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. iHome iD95 iPod Adapter Replacement: passo 5, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 5, imagem 2 %32
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
    Pergunte ao FixBot
    Comentar
  6. iHome iD95 iPod Adapter Replacement: passo 6, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 6, imagem 2 %32
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
    Pergunte ao FixBot
    Comentar
  7. iHome iD95 iPod Adapter Replacement: passo 7, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 7, imagem 2 %32
    • Apply the same techniques from the previous step to remove the remaining side panel.
    Pergunte ao FixBot
    Comentar
  8. iHome iD95 iPod Adapter Replacement: passo 8, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 8, imagem 2 %32 iHome iD95 iPod Adapter Replacement: passo 8, imagem 3 %32
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
    Pergunte ao FixBot
    Comentar
  9. iHome iD95 iPod Adapter Replacement: passo 9, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 9, imagem 2 %32
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
    Pergunte ao FixBot
    Comentar
  10. iHome iD95 iPod Adapter Replacement: passo 10, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  11. iHome iD95 iPod Adapter Replacement, Speakers: passo 11, imagem 1 %32
    • Take out four 14 mm screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. iHome iD95 iPod Adapter Replacement: passo 12, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 12, imagem 2 %32 iHome iD95 iPod Adapter Replacement: passo 12, imagem 3 %32
    • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
    • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  13. iHome iD95 iPod Adapter Replacement: passo 13, imagem 1 %32
    • Lift and remove both speakers.
    Pergunte ao FixBot
    Comentar
  14. iHome iD95 iPod Adapter Replacement, iPod Adapter: passo 14, imagem 1 %32 iHome iD95 iPod Adapter Replacement, iPod Adapter: passo 14, imagem 2 %32
    • Flip the logic board over.
    • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
    Pergunte ao FixBot
    Comentar
  15. iHome iD95 iPod Adapter Replacement: passo 15, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 15, imagem 2 %32
    • Remove two 4 mm-head 12 mm-length screws using a Phillips #1 screwdriver.
    • Pull the iPod adapter from the top cover.
    Pergunte ao FixBot
    Comentar
  16. iHome iD95 iPod Adapter Replacement: passo 16, imagem 1 %32 iHome iD95 iPod Adapter Replacement: passo 16, imagem 2 %32
    • Use a Phillips #1 screwdriver to take out the two, 12 mm-length 4 mm-head, screws holding the iPod adapter to its casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Vincent Chan
Membro desde: 04/18/13
19 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-37, Amido Spring 2013 Membro de Cal Poly, Team 12-37, Amido Spring 2013
CPSU-AMIDO-S13S12G37
4 Membros
Autoria de 7 guias
1Comentário do guia
Great article. I have an iHome iDL95 and would like to swap the Lightening adapter with a 30-pin adapter so that I can utilize my iPod 5.5 Classic. Is this possible? If so, where do I obtain the required 30-pin replacement adapter? Thanks.
P. Matt - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 2,266
