Ir para o conteúdo principal
iHome IH11 Main Motherboard Replacement
O que você precisa
  1. iHome IH11 Main Motherboard Replacement, Outer Case: passo 1, imagem 1 %32
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: passo 2, imagem 1 %32 iHome IH11 Main Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: passo 4, imagem 1 %32 iHome IH11 Main Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: passo 5, imagem 1 %32
    • Solder each wire to corresponding input on the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 14-9, Maness Spring 2013 Membro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 370
