Ir para o conteúdo principal
iHome IH11 Dock Connector Replacement
O que você precisa
  1. iHome IH11 Dock Connector Replacement, Dock Connector: passo 1, imagem 1 %32
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: passo 2, imagem 1 %32 iHome IH11 Dock Connector Replacement: passo 2, imagem 2 %32
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: passo 3, imagem 1 %32
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
Conclusão
3 outras pessoas executaram este guia.
Nick Knowles
Membro desde: 04/19/13
21 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-9, Maness Spring 2013 Membro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
Membros da 5
Autoria de 5 guias
2 comentários
Where can I buy a replacement dock connector?
A Ross - Responder
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 2,414
