Ir para o conteúdo principal
iHome IH11 AC Power Adapter Replacement
O que você precisa
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: passo 1, imagem 1 %32
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
  2. iHome IH11 AC Power Adapter Replacement: passo 2, imagem 1 %32 iHome IH11 AC Power Adapter Replacement: passo 2, imagem 2 %32
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
  3. iHome IH11 AC Power Adapter Replacement: passo 3, imagem 1 %32
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: passo 4, imagem 1 %32 iHome IH11 AC Power Adapter Replacement, Motherboard: passo 4, imagem 2 %32
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 AC Power Adapter Replacement: passo 5, imagem 1 %32
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
  6. iHome IH11 AC Power Adapter Replacement: passo 6, imagem 1 %32 iHome IH11 AC Power Adapter Replacement: passo 6, imagem 2 %32
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
Conclusão
Nick Knowles
Membro desde: 04/19/13
21 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-9, Maness Spring 2013 Membro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 758
