Ir para o conteúdo principal
iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement
O que você precisa
  1. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    Pergunte ao FixBot
    Comentar
  2. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  3. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Pergunte ao FixBot
    Comentar
  4. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 4, imagem 1 %32
    • If the computer has an AirPort card installed, follow the next three steps to remove it.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
    Pergunte ao FixBot
    Comentar
  5. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 5, imagem 1 %32
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
    Pergunte ao FixBot
    Comentar
  6. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 6, imagem 1 %32
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
    Pergunte ao FixBot
    Comentar
  7. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 7, imagem 1 %32
    • Remove the four silver Phillips screws that secure the RAM shield.
    Pergunte ao FixBot
    Comentar
  8. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 8, imagem 1 %32
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Pergunte ao FixBot
    Comentar
  9. iBook G4 12" 800 MHz-1.2 GHz Keyboard Replacement: passo 9, imagem 1 %32
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 16,820
