Ir para o conteúdo principal
iBook G3 Clamshell Display Replacement
O que você precisa
  1. iBook G3 Clamshell Display Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
    Pergunte ao FixBot
    Comentar
  2. iBook G3 Clamshell Display Replacement, Airport Card: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
    Pergunte ao FixBot
    Comentar
  3. iBook G3 Clamshell Display Replacement: passo 3, imagem 1 %32
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    Pergunte ao FixBot
    Comentar
  4. iBook G3 Clamshell Display Replacement: passo 4, imagem 1 %32
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
    Pergunte ao FixBot
    Comentar
  5. iBook G3 Clamshell Display Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two Phillips screws that secure the RAM shield.
    Pergunte ao FixBot
    Comentar
  6. iBook G3 Clamshell Display Replacement: passo 6, imagem 1 %32
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
    Pergunte ao FixBot
    Comentar
  7. iBook G3 Clamshell Display Replacement: passo 7, imagem 1 %32
    • Pull up the keyboard connector cable by its clear plastic loop.
    Pergunte ao FixBot
    Comentar
  8. iBook G3 Clamshell Display Replacement, Upper Case: passo 8, imagem 1 %32
    • Use a straightened paperclip to manually eject the CD-ROM tray.
    Pergunte ao FixBot
    Comentar
  9. iBook G3 Clamshell Display Replacement: passo 9, imagem 1 %32
    • Turn the computer over so that the bottom is facing up.
    • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
    Pergunte ao FixBot
    Comentar
  10. iBook G3 Clamshell Display Replacement: passo 10, imagem 1 %32
    • Pull the CD-ROM drive tray partly out.
    • Remove the silver Phillips screw from the plastic casing.
    Pergunte ao FixBot
    Comentar
  11. iBook G3 Clamshell Display Replacement: passo 11, imagem 1 %32
    • Turn the computer over.
    • Remove the three Phillips screws.
    Pergunte ao FixBot
    Comentar
  12. iBook G3 Clamshell Display Replacement: passo 12, imagem 1 %32
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Pergunte ao FixBot
    Comentar
  13. iBook G3 Clamshell Display Replacement: passo 13, imagem 1 %32
    • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the clamp.
    Pergunte ao FixBot
    Comentar
  14. iBook G3 Clamshell Display Replacement: passo 14, imagem 1 %32
    • Do not lift the upper case too far without first disconnecting the audio cable.
    • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
    • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
    Pergunte ao FixBot
    Comentar
  15. iBook G3 Clamshell Display Replacement: passo 15, imagem 1 %32
    • Disconnect the audio cable.
    Pergunte ao FixBot
    Comentar
  16. iBook G3 Clamshell Display Replacement: passo 16, imagem 1 %32
    • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
    • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
    Pergunte ao FixBot
    Comentar
  17. iBook G3 Clamshell Display Replacement, Modem: passo 17, imagem 1 %32
    • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
    • Remove the EMI fingers.
    Pergunte ao FixBot
    Comentar
  18. iBook G3 Clamshell Display Replacement: passo 18, imagem 1 %32
    • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
    Pergunte ao FixBot
    Comentar
  19. iBook G3 Clamshell Display Replacement: passo 19, imagem 1 %32
    • Remove the Phillips screw from the left side of the modem.
    • Pry up the right side of the modem.
    Pergunte ao FixBot
    Comentar
  20. iBook G3 Clamshell Display Replacement: passo 20, imagem 1 %32
    • Lift the modem partially out and disconnect the cable on the left side.
    Pergunte ao FixBot
    Comentar
  21. iBook G3 Clamshell Display Replacement, Display: passo 21, imagem 1 %32
    • Remove the Phillips screw from the left hinge.
    • Peel up the airport cable from beneath the yellow tape.
    Pergunte ao FixBot
    Comentar
  22. iBook G3 Clamshell Display Replacement: passo 22, imagem 1 %32
    • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
    Pergunte ao FixBot
    Comentar
  23. iBook G3 Clamshell Display Replacement: passo 23, imagem 1 %32
    • Disconnect the backlight cable from the logic board and deroute it.
    Pergunte ao FixBot
    Comentar
  24. iBook G3 Clamshell Display Replacement: passo 24, imagem 1 %32
    • Remove the three small Phillips screws from the clutch cover.
    Pergunte ao FixBot
    Comentar
  25. iBook G3 Clamshell Display Replacement: passo 25, imagem 1 %32
    • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
    • Remove the display assembly.
    • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
2Comentários do guia
Veryinformativeandexcellentguideforibookclamshell.thankyou.
Renee Blakemore - Responder Compartilhar
Wait, so is the display the whole clamshell? There isn't steps to swap out the display inside the clamshell?
The Wonderer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 32
Últimos 30 dias: 145
Ao todo: 18,842
