Ir para o conteúdo principal
iBook G3 12" RAM Replacement
O que você precisa
  1. iBook G3 12" RAM Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  2. iBook G3 12" RAM Replacement, Keyboard: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Pergunte ao FixBot
    Comentar
  3. iBook G3 12" RAM Replacement: passo 3, imagem 1 %32
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    Pergunte ao FixBot
    Comentar
  4. iBook G3 12" RAM Replacement: passo 4, imagem 1 %32
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    Pergunte ao FixBot
    Comentar
  5. iBook G3 12" RAM Replacement: passo 5, imagem 1 %32
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    Pergunte ao FixBot
    Comentar
  6. iBook G3 12" RAM Replacement: passo 6, imagem 1 %32
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    Pergunte ao FixBot
    Comentar
  7. iBook G3 12" RAM Replacement: passo 7, imagem 1 %32
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Pergunte ao FixBot
    Comentar
  8. iBook G3 12" RAM Replacement: passo 8, imagem 1 %32
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Pergunte ao FixBot
    Comentar
  9. iBook G3 12" RAM Replacement, RAM: passo 9, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  10. iBook G3 12" RAM Replacement: passo 10, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
    Pergunte ao FixBot
    Comentar
Conclusão
47 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 54
Ao todo: 34,688
