Ir para o conteúdo principal
iBUYPOWER Y40 IBP Thermal Paste Replacement
O que você precisa
  1. iBUYPOWER Y40 IBP Thermal Paste Replacement, Thermal Paste: passo 1, imagem 1 %32
    • Shut down the computer completely and unplug the power cable before opening the case.
    • Allow the system to cool for several minutes before you begin the repair.
    • Never work inside the computer while it is still connected to power.
    Pergunte ao FixBot
    Comentar
  2. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 2, imagem 1 %32 iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 2, imagem 2 %32 iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 2, imagem 3 %32
    • Carefully remove the tempered glass side panel to access the internal components of the desktop.
    • Place the panel somewhere safe to avoid scratches or damage.
    • Handle the glass panel carefully to prevent breakage or scratches.
    • Identify the CPU cooler mounted on top of the processor. It must be removed to access the processor and replace the thermal paste.
    • In this system, a liquid CPU cooler is installed with a pump block connected to the radiator.
    Pergunte ao FixBot
    Comentar
  3. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to loosen the CPU cooler screws in a cross pattern, loosening each screw gradually to avoid uneven pressure.
    Pergunte ao FixBot
    Comentar
  4. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 4, imagem 1 %32
    • Gently lift the CPU cooler straight out from the processor.
    • If it feels stuck, slightly twist it to break the seal of the old thermal paste before lifting.
    • Do not touch the surface of the CPU with your fingers, as oils from your skin can affect performance.
    Pergunte ao FixBot
    Comentar
  5. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 5, imagem 1 %32
    • Apply a small amount of 90% isopropyl alcohol to a microfiber cloth and gently wipe the old thermal paste from both the CPU and the bottom of the cooler.
    • Continue cleaning until both surfaces are completely clean and dry.
    • Apply a pea-sized amount of new thermal paste to the center of the CPU.
    Pergunte ao FixBot
    Comentar
  6. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 6, imagem 1 %32
    • Place the CPU cooler back over the processor and align it with the mounting holes.
    • Tighten the screws evenly to secure the CPU cooler in place.
    • Check that the CPU cooler is properly seated and all screws are tightened securely.
    Pergunte ao FixBot
    Comentar
  7. iBUYPOWER Y40 IBP Thermal Paste Replacement: passo 7, imagem 1 %32
    • Reconnect the power cable, close the case, and power on the system.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jaylen Emanuel
Membro desde: 02/27/26
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 74
