Ir para o conteúdo principal
iBUYPOWER WA550B Solid-State Drive Replacement
O que você precisa
    1. iBUYPOWER WA550B Solid-State Drive Replacement, SSD: passo 1, imagem 1 %32 iBUYPOWER WA550B Solid-State Drive Replacement, SSD: passo 1, imagem 2 %32
      • Remove the 6mm thumbscrews for the side panels.
      • You should be able to use your index finger and thumb to remove the screws. You can also use the Phillips #0 Screwdriver.
      Pergunte ao FixBot
      Comentar
    2. iBUYPOWER WA550B Solid-State Drive Replacement: passo 2, imagem 1 %32 iBUYPOWER WA550B Solid-State Drive Replacement: passo 2, imagem 2 %32
      • Slide each side panel off.
      Pergunte ao FixBot
      Comentar
    3. iBUYPOWER WA550B Solid-State Drive Replacement: passo 3, imagem 1 %32
      • Remove both the SATA power and the SATA data cables from the SSD.
      Pergunte ao FixBot
      Comentar
    4. iBUYPOWER WA550B Solid-State Drive Replacement: passo 4, imagem 1 %32
      • Remove the SSD mounting bracket from the case of the computer.
      Pergunte ao FixBot
      Comentar
    5. iBUYPOWER WA550B Solid-State Drive Replacement: passo 5, imagem 1 %32
      • Use the Phillips #0 Screwdriver to remove the 9mm HDD screws from the SSD that are holding it to the hard drive case.
      Pergunte ao FixBot
      Comentar
    6. iBUYPOWER WA550B Solid-State Drive Replacement: passo 6, imagem 1 %32
      • Remove the broken SSD from the mounting bracket.
      Pergunte ao FixBot
      Comentar
    7. iBUYPOWER WA550B Solid-State Drive Replacement: passo 7, imagem 1 %32
      • Place the new SSD in the hard drive case, and line it up with the screw holes.
      Pergunte ao FixBot
      Comentar
Conclusão
You have now successfully replaced the SATA Solid-State Drive for your computer!
Zachary Pendley
Membro desde: 03/28/20
217 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 3,176
