Ir para o conteúdo principal
e-lite web150 Disassembly
O que você precisa
    1. e-lite web150 Disassembly, removing the blower nozzle: passo 1, imagem 1 %32
      • Firmly press the yellow button and slide the blower nozzle off.
      Pergunte ao FixBot
      Comentar
    2. e-lite web150 Disassembly, un-screwing: passo 2, imagem 1 %32
      • un-screw all of the screws
      Pergunte ao FixBot
      Comentar
    3. e-lite web150 Disassembly, opening: passo 3, imagem 1 %32
      • pull apart the 2 halves
      Pergunte ao FixBot
      Comentar
    4. e-lite web150 Disassembly, The inside: passo 4, imagem 1 %32
      • This is the inside of the blower
      Pergunte ao FixBot
      Comentar
    5. e-lite web150 Disassembly, pulling out the switch and plug: passo 5, imagem 1 %32 e-lite web150 Disassembly, pulling out the switch and plug: passo 5, imagem 2 %32
      • gently pull out the power plug and switch
      Pergunte ao FixBot
      Comentar
    6. e-lite web150 Disassembly, removing the motor: passo 6, imagem 1 %32 e-lite web150 Disassembly, removing the motor: passo 6, imagem 2 %32
      • gently pull out the motor paying attention to which side it came out of.
      Pergunte ao FixBot
      Comentar
    7. e-lite web150 Disassembly, putting the motor back in: passo 7, imagem 1 %32
      • clean the dust out if you need to. then carefully put the motor back in making sure you put both of the tabs on the motor into their respective slots. you can't see the other one because I had to crop it out.
      Pergunte ao FixBot
      Comentar
    8. e-lite web150 Disassembly, putting the plugs back in their places: passo 8, imagem 1 %32
      • carefully put the plugs back into their holders.
      Pergunte ao FixBot
      Comentar
    9. e-lite web150 Disassembly, closing it up: passo 9, imagem 1 %32
      • fit the 2 halves back together
      Pergunte ao FixBot
      Comentar
    10. e-lite web150 Disassembly, screwing in the screws: passo 10, imagem 1 %32
      • replace all of the screws
      Pergunte ao FixBot
      Comentar
    11. e-lite web150 Disassembly, re-attaching the blower nozzle: passo 11, imagem 1 %32
      • slide the blower nozzle on to the main body until it locks in place, you are done.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Alex Pollard
Membro desde: 11/07/16
119 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 726
