Ir para o conteúdo principal
dreamGEAR Quad Dock Pro Electrical Port Replacement
O que você precisa
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: passo 1, imagem 1 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: passo 1, imagem 2 %32
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 2, imagem 1 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 2, imagem 2 %32
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 3, imagem 1 %32
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: passo 4, imagem 1 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: passo 4, imagem 2 %32
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 5, imagem 1 %32
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 6, imagem 1 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: passo 7, imagem 1 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: passo 7, imagem 2 %32 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
Conclusão
Uma outra pessoa concluiu este guia.
Jacob
Membro desde: 03/11/15
757 Reputação
Autoria de 6 guias
Equipe
Colorado Springs, Team 4-4, Panko Spring 2015 Membro de Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 331
