Introdução
Directions for opening bObi and removing the touch sensor strip under the bumper pads. For help closing bObi, see Closing bObi's Cover Post-Repair
O que você precisa
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
The sensor strips underneath bObi's 80 exterior touch sensors are attached to the cover circuit board by two wires, one red one white.
The circuit plug on the left communicates with bObi's right half of touch sensors.
The plug on the right controls bObi's left half of touch sensors.
Remove the appropriate touch sensor's circuit plug from the cover's circuit board.
Firmly press the circuit plug for the replacement sensor in to the open space.
To put bObi back together, follow the steps in the reassembly guide: Closing bObi's Cover Post-Repair
For instructions on how to reassemble bObi's cover, check out the guide Closing bObi's Cover Post-Repair
