Ir para o conteúdo principal
Zune Flash 2nd Generation Back Cover Replacement
O que você precisa
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
    Pergunte ao FixBot
    Comentar
  2. Zune Flash 2nd Generation Back Cover Replacement: passo 2, imagem 1 %32 Zune Flash 2nd Generation Back Cover Replacement: passo 2, imagem 2 %32
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
    Pergunte ao FixBot
    Comentar
  3. Zune Flash 2nd Generation Back Cover Replacement: passo 3, imagem 1 %32
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Zune Flash 2nd Generation Back Cover Replacement: passo 4, imagem 1 %32 Zune Flash 2nd Generation Back Cover Replacement: passo 4, imagem 2 %32 Zune Flash 2nd Generation Back Cover Replacement: passo 4, imagem 3 %32
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
    Pergunte ao FixBot
    Comentar
  5. Zune Flash 2nd Generation Back Cover Replacement: passo 5, imagem 1 %32 Zune Flash 2nd Generation Back Cover Replacement: passo 5, imagem 2 %32 Zune Flash 2nd Generation Back Cover Replacement: passo 5, imagem 3 %32
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
    Pergunte ao FixBot
    Comentar
Conclusão
ybahman
Membro desde: 11/01/09
139 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-20, Regan Fall 2009 Membro de Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 39
Ao todo: 4,210
