Ir para o conteúdo principal
Zoomer Jurassic World Indominus Rex Motherboard Replacement
O que você precisa
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 2, imagem 1 %32 Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 2, imagem 2 %32
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 3, imagem 1 %32 Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 3, imagem 2 %32
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 5, imagem 1 %32 Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: passo 6, imagem 1 %32
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Use caution while soldering to avoid being burned.
Conclusão
Anh Le
Membro desde: 01/20/16
504 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membro de USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 763
